GTC Auto Shop
Pagina 2 din 7 PrimulPrimul 1234567 UltimaUltima
Afisez rezultatele 11 la 20 din 67
  1. #11
    Implicit Re: Povestea merge mai departe.(Mi-am mai implinit un vis by Max)
    turbo si rugina.Frumoasa combinatie.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	178361   Click image for larger version.
ID:	178358   Click image for larger version.
ID:	178362   Click image for larger version.
ID:	178363   Click image for larger version.
ID:	178364   Click image for larger version.
ID:	178365   Click image for larger version.
ID:	178366   Click image for larger version.
  2. #12
    In lucru la table.
ID:	181170   Click image for larger version.
ID:	181171   Click image for larger version.
ID:	181172   Click image for larger version.
ID:	181173   Click image for larger version.
ID:	181174   Click image for larger version.
ID:	181175   Click image for larger version.
ID:	181176   Click image for larger version.
ID:	181177   Click image for larger version.
ID:	181178   Click image for larger version.
ID:	181179   Click image for larger version.
ID:	181180   Click image for larger version.
ID:	181181   Click image for larger version.
ID:	181182   Click image for larger version.
ID:	181183   Click image for larger version.
ID:	181189   Click image for larger version.
ID:	181190   Click image for larger version.
ID:	181191   Click image for larger version.
  3. #13
    Mai punem ceva poze.Avansam incetisor,cu rabdare ca nu-i concurs,sa iasa treaba buna.
ID:	197610 Click image for larger version.
ID:	197620 Click image for larger version.
ID:	197622 Click image for larger version.
ID:	197624 Click image for larger version.
ID:	197626 Click image for larger version.
ID:	197617 Click image for larger version.
ID:	197608 Click image for larger version.
ID:	197612 Click image for larger version.
ID:	197614 Click image for larger version.
ID:	197616 Click image for larger version.
  4. #14
    Data Inscriere
    May 2007
    Localitate
    Baia Mare
    Varsta
    45
    Mesaje
    7,644
    Masina
    Toyota Landcruiser HJ60 '85, HJ61 '88, FJ62 '88
    Nu putea sa intre pe maini mai bune masina asta.
    Treaba asta mai atenueaza o parte din supararea ca am dat-o.
    Spor la treaba in cotinuare!
    "Nu stiu care e cheia succesului dar stiu care e cheia esecului: Sa incerci sa ii multumesti pe toti"
  5. #15
    Data Inscriere
    Oct 2011
    Localitate
    Braila si Franta
    Varsta
    35
    Mesaje
    97
    Masina
    Nissan Pick-Up MD21 King Cab '93
    Va felicit! ma uit la suduri si mi se par excelente. Tot respectul pt munca si pasiune.
    of topic: ce amestec de gaze folositi? ce setari la aparatul de sudura si ce tabla pt petice?
  6. #16
    Data Inscriere
    Nov 2008
    Localitate
    Loc. Gilau jud. Cluj
    Varsta
    37
    Mesaje
    173
    Masina
    Nissan Patrol Y60
    Aprecieri pentru munca si pasiunea pe care o depui, rezultatul va fi unul pe masura. Spor.
    La tratarea ruginei cu Fertan cum se procedeaza?
    Se pune pe rugina si apoi se vopseste peste sau....
    Respect.
    TODAY IS A GIFT
  7. #17
    Va multumesc pentru aprecieri si ma bucur ca imi puneti intrebari tehnice.Pentru suduri estetice folosesc Mig-Mag cu corgon si uneori WIG,pentru cele de profunzime folosesc CO2.Am folosit doar tabla de 1,5 tabla neagra si tabla de inox 1,5 pe zonele de imbinare sau dubluri.Am folosit fertanul doar pentru a starpi inceputuri de rugina.Este foarte bun,aplici un strat,il lasi 2 zile sa lucreze si-l dai jos cu peria de sarma.Daca stratul de rugina este mai gros,repeti operatia pana ramane curat.Legat de aparatul de sudura mi-e greu sa dau valori exacte.Cu cat maresti amperajul cresti viteza de avans a sarmei,am reglat gazul din regulator aproape de 1 bar.Pana la urma iti faci toate reglajele dupa ureche si ochi,sudura trebuie sa sclipeasca,chiar sa ai impresia ca e uda,sa nu aiba pori sau forme tuguiate.Trebuie sa o vezi intinsa,in acelasi timp sa fie vizibila si din partea opusa.
    Ii sfatuiesc pe cei care invata sa sudeze in puncte,sa foloseasca curent mai mare in intervale de timp mai scurte decat invers.Operatia este mai delicata si cu riscuri de gaurire a suprafetei insa mult mai rezistenta.
    Oricarui incepator ii recomand sa aiba in garaj un MIG-MAG pana la 160-180 Amperi si o butelie de CO2.Nimic mai mult.Noroc.
  8. #18
    Data Inscriere
    May 2007
    Localitate
    Bucuresti
    Varsta
    46
    Mesaje
    220
    Bai Emile da avansezi nu gluma....!!!!!!! cand ma uit aici imi dau seama ca "frec duda" dupa sarbatori ma apuc de cautat "cazan" ca prea stau linistit !!!!!
    Altfel ce sa zic SUPER TARE !!!!!!!!!!!!!!
    Salutari si Sarbatori Fericite !!!!!!!!
    P.S.- 1 Sa ne mai pui poze !!!!
    - 2 Ai taiat aripile spate pentru overfendere (s-au nu-i pui )???
  9. #19
    Citat Postat original de matake70 Vizualizare Mesaj
    Marius draga,nu am taiat aripile,doar am prelungit putin curbura aripilor de spate cam 2-3 degete in asa fel incat sa nu sara in ochi modificarea si sa nu atinga 35-ul pe comprimare.In rest ca modificari,am inversat doar cerceii pe fata si am pus lame de la Trailmaster iar pe spate am compensat cu inca 2 elicoidale.Overfendere trebuie obligatoriu dar nu vreau fibra sau plastic.Ma gandesc la ceva metallic rezistent,inca nu m-am hotarat.Pozele astea sunt destul de vechi.Lucrarea e mult mai avansata.Masina este acum la vopsitor si tinand cont ca e momentul propice,am sa-I schimb si culoarea.Nu-mi place rosu decat daca e pe ferari.Pe masinile astea le prind mai bine culorile discrete nicidecum cele aprinse.Nu va spun culoarea,va fi surpriza.
    Cat despre tine,ma mir ca inca nu te-ai apucat de o noua bataie de cap.
  10. #20
    Data Inscriere
    Aug 2007
    Localitate
    Bucuresti
    Varsta
    39
    Mesaje
    260
    Masina
    Toyota Landcruiser Lj70, Hzj 73-1Hd-t, Bj 73, LJ 78, Uzj 100
    Red face Re: Povestea merge mai departe.(Mi-am mai implinit un vis by Max)
    Fain acaretul, pe pe spate raman amortizoarele OEM?
    @Landcruiser
Discutii Similare
  1. Raspunsuri: 12
    :: 12th June 2013, 22:01
  2. Un vis implinit
    By Pralicel in forum Samurai, SJ, LJ
    Raspunsuri: 5
    :: 30th May 2013, 09:58
  3. Mi-am mai implinit un vis.
    By Max in forum Landcruiser J4
    Raspunsuri: 99
    :: 21st March 2013, 16:46
  4. Mi-am mai implinit un vis.
    By Max in forum Landcruiser J6
    Raspunsuri: 15
    :: 13th August 2010, 00:33
