vertical Posted October 6, 2010 Share Posted October 6, 2010 Masina mea are ca si an de fabricatie 1997 si acum ceva zile am mers cu ea la service pentru a schimba tamburii spate de la frana de mana,bielete la directie si un pivot , iar cei de service mi-au spus ca nu sunt piese pentru modelul meu, sau ca ar fi dar nu se potrivesc ! Nelamurirea mea este daca au dreptate ca se gasesc greu sau nu au vrut sa faca treaba ! Voi unde reparati masinile !? MS Link to comment Share on other sites More sharing options...
u2_2 Posted October 6, 2010 Share Posted October 6, 2010 Re: Problema tamburi spate SsangYong `97 Treci pe la Unix. Vezi la Maurizio, are sigur. Link to comment Share on other sites More sharing options...
u2_2 Posted October 7, 2010 Share Posted October 7, 2010 Re: Problema tamburi spate SsangYong `97 dau reply, nu editez, ca sa vezi postul. Pe okazii era un tip care are un korando bucati, de vanzare. Parca era la Focsani. Avea tot ce vrei. Link to comment Share on other sites More sharing options...
andy Posted October 10, 2010 Share Posted October 10, 2010 Re: Problema tamburi spate SsangYong `97 TAMBURI!!!!!? OK te pot ajuta dar eu in locul tau as converti puntea spate ( foarte usor!) pe discuri! Link to comment Share on other sites More sharing options...
vertical Posted October 11, 2010 Author Share Posted October 11, 2010 Re: Problema tamburi spate SsangYong `97 Eu puntea pe spate o am cu discuri numai ca la frana de mana e cu tamburi ! Link to comment Share on other sites More sharing options...
danxnv Posted March 7, 2011 Share Posted March 7, 2011 Re: Problema tamburi spate SsangYong `97 Salut. Ai reusit sa rezolvi problema cu frana de mana? Link to comment Share on other sites More sharing options...
vertical Posted May 5, 2011 Author Share Posted May 5, 2011 Re: Problema tamburi spate SsangYong `97 Nu am mai rezolvat nimic ...... ! Lipsa timpului..... Link to comment Share on other sites More sharing options...
meffy Posted May 15, 2012 Share Posted May 15, 2012 Re: Problema tamburi spate SsangYong `97 Salut, si eu am probleme cu frana de mana. Cand am cautat am gasit sabotii la Unix, undeva pe la 400 RON. Nu i-am rezolvat pentru ca nu sunt convins ca cu saboti noi o sa rezolv problema. Cumva uzura la sabotii existenti nu este mare, si este numai la capete. Am reglat cat am putut, dar parerea mea este ca excentricul ar trebui marit, ca sa mareasca actiunea. Sunt curios daca tu ai rezolvat. Numai bine SSangYong Korando 2.3i GPL Link to comment Share on other sites More sharing options...
andy Posted May 30, 2012 Share Posted May 30, 2012 Re: Problema tamburi spate SsangYong `97 Salut, si eu am probleme cu frana de mana. Cand am cautat am gasit sabotii la Unix, undeva pe la 400 RON. Nu i-am rezolvat pentru ca nu sunt convins ca cu saboti noi o sa rezolv problema. Cumva uzura la sabotii existenti nu este mare, si este numai la capete. Am reglat cat am putut, dar parerea mea este ca excentricul ar trebui marit, ca sa mareasca actiunea. Sunt curios daca tu ai rezolvat. Numai bine Poti sa schimbi excentricul,sa o reglezi sa schimbi saboti ,sa-o ..... pentru ca tot 2 luni maxim o sa tina frana de mana !!!!! Este idioata proiectata din fabricatie! Ai 2 soluti una sa ii pui saboti normali si tot mecanismul de la o masina cu acelasi diametru la tamburi ,ori ( varianta mea ) o faci hidraulica cu un cilindru receptor de ford escort. Link to comment Share on other sites More sharing options...
