nas ne dagoniat Posted January 9, 2015 Share Posted January 9, 2015 Error Code Table Multipoint from EURO 3/4 Code Description P0102 Mass air consumption donor, low output level P0103 Mass air consumption donors, high output level P0112 Temperature sensor d.Ansaugluft, lower output level P0113 Temperature sensor d.Ansaugluft, high output level P0116 Cooling water temperature sender, except Allowable signal. Area P0117 Cooling water temperature gauge, low output level P0118 Cooling water temperature gauge, high output level P0122 Throttle position sensor, low output P0123 Throttle position sensor, high output level P0130 Lambda probe in front exhaust catalyst is defective P0131 Lambda probe in front of catalytic exhaust gas, lower output level P0132 Lambda probe in front of catalytic exhaust gas, high output level P0133 Lambda probe in front of catalytic exhaust gas, slow response signal to enrichment or emaciation P0134 Lambda probe in front of catalytic exhaust gas converter, signal circuit interruption P0135 Lambda probe in front of catalytic exhaust gas, disturbance of the probe heating P0136 Lambda sensor on the exhaust gas catalyst, ground fault signal circuit P0137 Lambda sensor on the exhaust gas catalyst, low signal level P0138 Lambda sensor on the exhaust gas catalyst, high signal level P0140 Lambda sensor on the exhaust gas catalyst, signal circuit interruption P0141 Lambda sensor on the exhaust gas catalyst, disturbance of probe heating P0171 Fuel feed system arm (mixture too lean) P0172 Fuel Supply System too rich (too rich mixture) P0201 Interruption of the nozzle control circuit, cylinder? 1 P0202 Interruption of the nozzle control circuit, cylinder? 2 P0203 Interruption of the nozzle control circuit, cylinder? 3 P0204 Interruption of the nozzle control circuit, cylinder? 4 P0261 Nozzle control circles, cylinders? 1, ground fault P0262 Nozzle control circles, cylinders? 1, short circuit + 12V P0264 Nozzle control circles, cylinders? 2, ground fault P0265 Nozzle control circles, cylinders? 2, Short + 12V P0267 Nozzle control circles, cylinders? 3, ground fault P0268 Nozzle control circles, cylinders? 3, Short + 12V P0270 Nozzle control circles, cylinders? 4, earth fault P0271 Nozzle control circles, cylinders? 4, short circuit + 12V P0300 Adventitious / multiple ignition misfires P0301 Determined ignition misfire in cylinder 1 P0302 Determined ignition misfire in cylinder 2 P0303 Determined ignition misfire in cylinder 3 P0304 Determined ignition misfire in cylinder 4. P0327 Knock sensor, low signal level P0328 Knock sensor, high signal level P0335 Kurbenwellenstellunggeber, no signal P0336 Kurbenwellenstellunggeber, except Allowable signal. Area P0337 Kurbenwellenstellunggeber, short to ground P0338 Kurbenwellenstellunggeber, chain termination P0340 Camshaft Position Sensor - Circuit Malfunction P0342 Camshaft position sensor, low signal level P0343 Camshaft position sensor, high signal level P0422 Below the exhaust gas catalyst, effectiveness P0441 Air consumption through valve is not correct P0443 Disturbance in the control of the Adsorberspülventils P0480 Relay control circuit for fan 1; Demolition, short circuit + 12V or ground fault P0481 Relay control circuit, fan 2; Demolition, short circuit + 12V or ground fault P0500 Speed ??sensor no signal P0503 Motion sensor, intermittent signal P0506 Idle controller blocked, low speed P0507 Idle controller blocked, high speed P0560 Board power supply voltage falls below the functionality of the system P0562 Low-board supply voltage P0563 High-board supply voltage P0601 Error d. Checksum of the FLASH memory P0603 Error d. Checksum of the external RAM P0604 D error. Checksum of the internal RAM P0615 Control circuit of the starter relay, demolition P0616 Control circuit of the starter relay, short to ground P0617 Control circuit of the starter relay, short shot + 12V P1135 D.Lambda sensor heater circuit malfunction before exhaust catalyst P1140 Measured load differs from the calculated load P1141 D.Lambda sensor heater circuit malfunction after the exhaust catalyst P1386 Channel determining the spark knock, the inner error tests P1410 D.Adsorberspülventils control circuit, short circuit + 12V P1425 D.Adsorberspülventils control circuit, ground fault P1426 Control circuit d.Adsorberspülventils, demolition P1501 Control circuit of the fuel pump relay, earth fault P1502 Control circuit of the fuel pump relay, short circuit + 12V P1509 Overload of the control circuit d.Leerlaufreglers P1513 Control circuit of the idle controller, earth fault P1514 Control circuit of the idle controller, demolition or short circuit + 12V P1541 Control circuit of the fuel pump relay, demolition P1570 Immobilizer, no positive response or chain termination P1602 Power failure of the power supply circuit d.Steuergerätes P1606 Timer d. Rough road, the wrong message P1616 Timer d. Rough road, low signal P1617 Timer d. Rough road, high signal P1640 EEPROM memory error of reading-recording-test P1689 Fault in the fault memory Am deschis acest topic nu din dorinta de a nicarca forumul ci pentru a putea fi identificat mai usor fara a fi necesara o cautare mai greoaie prin funcatia de cautare si pt. ca am considerat ca va fi tot mai necesar deoarece NIVA alimentata pe carburatie devine tot mai mult istorie la modelele mai noi find necesara diagnosticare computerizata,si pt. ca am vazut colegi care se plang de mecanici care nu stiu interpreta codurile de eroare.Daca un moderator considera ca nu am procedat corect il rog sa mute topicul la locul pe care il cosidera adecvat sau sa l inchida in functie de alegerea domniei sale. 2 Link to comment Share on other sites More sharing options...
KAROLOKW Posted January 9, 2015 Share Posted January 9, 2015 (edited) Re: Coduri eroare - lada niva super tare!!! il copiez cu acordul tau si pe topicul meu in caz de problema cu postul asta :) Edited January 9, 2015 by Astral Link to comment Share on other sites More sharing options...
dan chiperi Posted January 9, 2015 Share Posted January 9, 2015 Re: Coduri eroare - lada niva :g tot astia :old , care mai misca cate ceva, ca mai e unii care au da nu dau:wink: :lr blackhttp://forum.club4x4.ro/showthread.php?61857-LADA-NIVA-IASI-quot-Natasha-quot/page15&highlight=iesire+iasi :lr whitehttp://forum.club4x4.ro/showthread.php?65728-Lada-Niva-1-7-i-multipunct/page52&highlight=lada+niva Link to comment Share on other sites More sharing options...
ubu Posted January 27, 2015 Share Posted January 27, 2015 Re: Coduri eroare - lada niva de genul : "merg cu ele sccrise-n palma", dar cu ce le citim de pe masina ? Link to comment Share on other sites More sharing options...
dan chiperi Posted January 27, 2015 Share Posted January 27, 2015 Re: Coduri eroare - lada niva ...pai nene ubu, te duci la astia cu diagnose si il pui sa-ti faca si tie o citire pe aparatul lui, dar in prealabil iti scrii si tu in palma codurile, ca astia de la romanica desi le apar codurile nu prea stiu ce e cu ele. Si le arati si lor fituica k sa copie si ei la "examen", ca daca au raspunsurile apoi stiu ei pe unde sa umble. ... sau ar mai fi o variant de a da vreo 250 eur parca pe un de ala de citit erori(sper sa nu gresesc) :lr blackhttp://forum.club4x4.ro/showthread.php?61857-LADA-NIVA-IASI-quot-Natasha-quot/page15&highlight=iesire+iasi :lr whitehttp://forum.club4x4.ro/showthread.php?65728-Lada-Niva-1-7-i-multipunct/page52&highlight=lada+niva Link to comment Share on other sites More sharing options...
ubu Posted January 27, 2015 Share Posted January 27, 2015 Re: Coduri eroare - lada niva a doua varianta poate fi varianta. pe prima o stiam si eu. Link to comment Share on other sites More sharing options...
adyhincu Posted February 4, 2015 Share Posted February 4, 2015 Re: Coduri eroare - lada niva Salut , In ultimele 2 saptamani am inceput sa am probleme cu Niva mea. Mi se aprinde becul check engine in bord si motorul incepe sa mearga putin neregulat si nu mai are putere. De asemenea relantiul nu mai tine deloc, sau tine undeva pe la 1300-1400 RPM. Dupa diagnoza (am un ELM 327) am primit urmatoarele coduri: p0102 mass or volume air flow circuit low imput p0123 throttle/pedal position senzor/switch "a" circuit high Din ce traduc eu, primul tine de debitmetrul de aer si al doilea de clapeta de acceleratie. Dupa ce am sters erorile, becul din bord s-a stins si motorul a mers perfect. M-am gandit ca a fost ceva temporar si si-a revenit. Dupa 40 km eroarea a aparut iar, cu aceleasi simptome, dar s-a stins singura si apoi a mers perfect. Nu am mai utilizat masina de atunci pentru ca e la tara, dar voi merge sambata sa ii schimb galeria de evacuare si probabil sa ii fac o curatare de clapeta. Am luat si un motoras pas cu pas (care tine relantiul) pentru ca majoritatea persoanelor pe care le-am intrebat mi-au spus ca acesta ar fi responsabil pentru problemele mele. [ATTACH=CONFIG]236065[/ATTACH] In paralel mai am si galeria de evacuare sparta (sufla din ce in ce mai rau) si urmeaza sa o inlocuiesc sambata. Bateria nu e in stare foarte buna, o am de pe un motor diesel care nu mai pornea cu ea. La mine mai merge inca. Din ce am observat si pornirea e putin mai greoaie, in sensul ca uneori trebuie sa ii apas putin acceleratia ca sa porneasca. Astept si parerile voastre, ale forum-istilor, ca poate s-a mai lovit cineva de aceste coduri de eroare. Sper sa nu ajung la schimbarea debitmetrului pentru ca e ceva mai scump. As avea totusi de unde sa iau un alt debitmetru si un senzor pentru clapeta ca sa fac proba cu ele. Mai rau e ca problema pare sa fie aleatorie si e cam greu sa imi dau seama care din ele e de vina. Multumesc, You can go fast but I can go ANYWHERE! Link to comment Share on other sites More sharing options...
adyhincu Posted February 9, 2015 Share Posted February 9, 2015 Re: Coduri eroare - lada niva Salut, Pana la urma am reusit sa schimb galeria de evacuare si motorasul pas cu pas care regleaza relantiul. erorile care le primeam inainte au reaparut pe rand. Mai intai a reaparut eroarea legata de debitmetru si l0-am inlocuit cu unul de la dezmembrari. La jumatate de ora mi-a reaparut si eroarea de la senzorul de acceleratie pe care am fost nevoit sa il schimb. Acum motorul merge ca nou. Multumesc, You can go fast but I can go ANYWHERE! Link to comment Share on other sites More sharing options...
Niva Posted January 4, 2016 Share Posted January 4, 2016 Re: Coduri eroare - lada niva La multi ani 2016 ! Sa fiti sanatosi si tot ce va doriti sa se implineasca ! Incerc sa revin pe meleagurile 4x4 , pe cel mai longeviv forum de 4x4 . Sa fiti iubiti ,...de trei ori pe zii ! Link to comment Share on other sites More sharing options...
Niva Posted January 4, 2016 Share Posted January 4, 2016 Re: Coduri eroare - lada niva Filtrul de aer murdar deterioreaza debitmetrul si motorasul pas cu pas : mers in gol dezechilibrat , rateu la accelerare . Link to comment Share on other sites More sharing options...
Liviu-San Posted January 4, 2016 Share Posted January 4, 2016 Re: Coduri eroare - lada niva La multi ani 2016 ! Sa fiti sanatosi si tot ce va doriti sa se implineasca ! Incerc sa revin pe meleagurile 4x4 , pe cel mai longeviv forum de 4x4 . Sa fiti iubiti ,...de trei ori pe zii ! La multi ani si tie si bine ai revenit! Tare ne-a fost dor de tine! :wink: :h5 :cl Link to comment Share on other sites More sharing options...
KAROLOKW Posted January 5, 2016 Share Posted January 5, 2016 Re: Coduri eroare - lada niva Filtrul de aer murdar deterioreaza debitmetrul si motorasul pas cu pas : mers in gol dezechilibrat , rateu la accelerare . cu debitmetrul ca il strica deacord :) da cu motorasul pas cu pas mai degraba vaporii de ulei reaspirat care formeaza un amestec lipicios si care in combinatie cu caldura se fac ca un lac:) Link to comment Share on other sites More sharing options...
Niva Posted January 6, 2016 Share Posted January 6, 2016 Re: Coduri eroare - lada niva ..si cu un pic de pulbere fins sa vezi ce rezulta ! Ce ajunge in debitmetru , ajunge si in corpcapeta +condensul de ulei = blocaj s-au reactie tirzie a motorasului pas cu pas . Cind revine injectia din cut off la 1200-1450 rpm motorasul nu e in pozitia ideala si motorul se opreste . Eu expun doar ce am observat , nu e obligatoriu a lua de bun informatia .:wink: Link to comment Share on other sites More sharing options...
KAROLOKW Posted January 6, 2016 Share Posted January 6, 2016 Re: Coduri eroare - lada niva deacord da pulbere fina sa ai trebuie ca filtrul ala sa nu fi fost schimbat niciodata sau mers doar prin macadam in spatele unui tir :) Link to comment Share on other sites More sharing options...
Niva Posted January 7, 2016 Share Posted January 7, 2016 Re: Coduri eroare - lada niva De acord cu tine , dar majoritatea care exploateaza masina in agricultura sau forestier nu prea tin cont de acest fenomen. Link to comment Share on other sites More sharing options...
nas ne dagoniat Posted January 7, 2016 Author Share Posted January 7, 2016 Re: Coduri eroare - lada niva :W NIVA Bacsi !!! Link to comment Share on other sites More sharing options...
adyhincu Posted July 16, 2019 Share Posted July 16, 2019 Salut, in ultima perioada am observat ca Niva mea porneste mai greu. dupa cateva zile s-a apris si martorul motor in bord. Am pus o diagnoza (ELM bluetooth) si am gasit urmatoarea eroare: P0340 camshaft position sensor "a" circuit (bank 1 or single sensor) Prin urmare am cumparat un senzor ax cu came, l-am schimbat, am sters eroarea si a pornit masina la sfert. pare ca si motorul tragea mai bine dupa acest schimb. Dupa prima tura cu masina, am oprit motorul iar la urmatoarea pornire a reaparut problema. Am sters iar eroarea, iar a mers bine pana in momentul in care am oprit motorul si a reparut problema la urmatoarea pornire. am verificat apoi firele, totul este perfect pana la intrarea in ECU. Are cineva idee ce as mai putea verifica? Citeam pe forumurile din afara ca e posibil sa am si un missfire rezultat poate de la vreo fisa, bujie sau injector...am verificat fisele si bujiile si totul este in regula. Dar ma gandeam ca pentru missfire ar fi trebuit totusi sa am alta eroare. Injectoarele se pot verifica cumva cu vreo interfata? Multumesc, You can go fast but I can go ANYWHERE! Link to comment Share on other sites More sharing options...
