Vand Kit suspensii pe aer Air Lift
rxn
Buna seara,
Din pricina unei achiitii gresite, vand acest fantastic kit de suspensii pe aer, pentru puntea spate, ideal pentru vehicule ce transporta permanent sau foarte des, incarcaturi substantiale.
Litul este nou, sigilat, usor de montat in aproximativ doua ore.
Fabricat in State.
160€
AIR LIFT 1000 Series Rear Air Spring Kit is designed to adjust the air spring level of the vehicle while towing. It includes hardware and durable component. This kit eliminates sag and features 2000 pounds of leveling capacity. It installs inside coil spring to eliminate bottoming out and is highly durable.
Up to 1,000 lbs. of load-leveling capacity*
Working with your existing coil springs, Air Lift 1000 air springs increase your safety and comfort when towing and hauling heavy loads.
Air Lift air spring kits includes everything you need to easily install, usually in 2 hours or less.
https://www.youtube.com/watch?v=TjI9ToaUFrw
27ff5390-71fe-484e-ae6b-fb275568067a.jpg._CB311298963__SL220__.jpg.339a590f59d07d082036f020bb18b32e.jpg
35b40953-a5fc-405d-94d2-0be985dbc8ce.jpg._CB311299035__SL220__.jpg.91331f266f158579aa418f0f3067cb24.jpg
f38c85d6-11d6-4737-bc61-c03197fe4e59.jpg._CB311298602__SL220__.jpg.03c8366e74cc5eb76871b06147536eff.jpg
f2524441-0acf-43d5-9ce5-8fbcc2ba0d94.jpg._CB311298674__SL220__.jpg.369c8ebe4ba750a73e3fe5d852908680.jpg
  • 11 months later...
