mariusg Postat Mai 15, 2010 Partajează Postat Mai 15, 2010 Re: surpriza in diagnoza LR Nu. Mi-au explicat ca in momentul cuplarii pe masina el ramine setat pe ea. Pentru a testa orice alta masina se updateaza prin cumparare unui soft suplimentar. Ideea cooptarii mai multor persoane din colturi diferite ale tarii (si nu numai) pentru achizitioanrea unui tester nu este deloc viabila. Ca orice afacere inceputa in mai multi. Land Rover Discovery 2 V8 Automatic -Thor Land Rover Discovery 2 Td5 Manual - Phoenix www.lroc.ro Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
sierrafery Postat Mai 15, 2010 Autor Partajează Postat Mai 15, 2010 Re: surpriza in diagnoza LR ..... Vezi ce se poate face in BCU, pentru ca am vazut ce a patit "provita" si e o belea foarte nasoala. La nivel de BCU am trecut prin toate cele de mai jos: Live Data Circuit Tests Horn Fuel Flap Alarm LED Ign Interlock Crank Enable Lock Doors Unlock Doors Superlock Doors Single Pt. Entry Front LH Window Front RH Window Rr Window Enable Sunroof Enable Front Wipe Enable Rear Wiper Enable H/Lamp Power Wash Front Fogs Relay LH Ind. Enable RH Ind. Enable Shift Interlock Transfer Neutral Sounder Check Engine Lamp LH Ind Warn Lamp �RH Ind Warn Lamp Check ACE Lamp Manual Lamp Diff. Lock Lamp Oil Pressure Lamp H/Temp Warn. Lamp Sport Warn Lamp Trans. Temp Lamp Alternator W/Lamp Trailer Indicator HDC Select W/Lamp ABS Warning Lamp Traction W/Lamp Check HDC W/Lamp Brake Warn. Lamp Seat Belt W/Lamp Glow Plug W/Lamp Check SLS W/Lamp Heated Rr Window Heat Rr Win Lamp Heated Front Lamp Programming Gearbox Front FOG Shift Interlock DRL Wash Wipe Key In Warning Electric Seat Electric Windows Heated Fr Screen Rear Win / Sun Roof Autographics HDC/SLABS Courtesy Lamps Error Warning �Seat Belt W/Lamp Seatbelt Sound Bulb Failure Superlock Unlocking Alarm Disarm Inertia Switch Speed Locking Volumetric Alarm Passive Hazards Mislock Alarm Sound Bath Robe Lock Alarm Tampered Eng. Immobilised Low Battery Warn EKA Live Data Circuit Tests Inlet Valve RF Outlet Valve RF Wheel Test RF Hydraulics RF Inlet Valve LF Outlet Valve LF Wheel Test LF Hydraulics LF Inlet Valve RR Outlet Valve RR Wheel Test RR Hydraulics RR Inlet Valve LR Outlet Valve LR Wheel Test LR Hydraulics LR Supplies / Grounds ABS Warning Lamp TC Warning Light Brake Warn. Lamp Shuttle Valve Sw. Valve Relay Pump Relay HDC Info. Light �HDC Fault Light Brake Light Relay Speedometer SLS RR Valve SLS LR Valve SLS Exhaust Valve SLS Cmpress Relay SLS RR Height SLS LR Height SLS Audible Warn SLS Warning Light OFF Road Light TC Valve NC TC Valve NO Isolation Inlet Rough Road Signal Programming Configuration Transportation Cele care nu le are masina in dotare pur si simplu scrie "not fitted" restul se pot testa toate, am trecut prin ele numai nu le-am testat chiar pe toate, mai am timp. La programare m-am bagat numai sa vad meniul ca pentru aia mai tre sa invat dar eu zic ca acopera tot ce poate fi diagnosticat...............primul lucru va fi sa-mi aloc un EKA pe care sa-l si stiu. NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
sierrafery Postat Iunie 15, 2010 Autor Partajează Postat Iunie 15, 2010 Re: surpriza in diagnoza LR @mariusg....Ai definitivat treaba aia cu Faultmate-ul, daca da povesteste-ne ceva te rog. NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
mariusg Postat Iunie 16, 2010 Partajează Postat Iunie 16, 2010 Re: surpriza in diagnoza LR @mariusg....Ai definitivat treaba aia cu Faultmate-ul, daca da povesteste-ne ceva te rog. Da am rezolvat. 550 eur cu transport acasa. Super amabili baietii din Cipru. L-am setat, am incarcat configuratia masinii si le-am transmis fisierul. Pe site la ei ti se da un utilizator si o parola si ai acces la toate updatarile forever. Bine inteles numai pentru configuratia pentru masina mea. Sunt module comune cam pentru toate benzinarele (al meu este benzina 3,9l 1999 dar este dotat full). Deci am asa ca module de test: SM005: NIPPON DENSO ATC SM009: BOSCH MOTRONIC M5.2.1 SM015: TRW SPS (TYPE 2A/DISCO II) SM016: WABCO SLABS SM023: VALEO BCU (DISCO II) SM030: BOSCH AUTO BOX GS8.87.0 SM032: LUCAS ACE Am facut citeva teste pe masina cu codurile de eroare care stiam ca imi apar si mie pe testerul oficial. Interesant este ca pot scrie si valori in modulele respective, adica le pot edita eu si salva. Este foarte vast. De 2 saptamini mai gasesc cite ceva de citit. Aaaa si au forum la fel ca la noi. Orice problema aparuta undeva este scrisa, explicata, rezolvata prompt si profesional de cei de la Blackbox. Inca citesc la forum, am de recuperat cam de prin 2005. Mai vorbim despre.... Daca aveti ceva coduri de eroare neexplicate va pot ajuta cautand la ei in forum. Atasez si niste explicatii la SM009. Land Rover Discovery 2 V8 Automatic -Thor Land Rover Discovery 2 Td5 Manual - Phoenix www.lroc.ro Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
flay Postat Octombrie 6, 2010 Partajează Postat Octombrie 6, 2010 (editat) Re: surpriza in diagnoza LR La nivel de BCU am trecut prin toate cele de mai jos: ,,,,,,,,,,,,, Cele care nu le are masina in dotare pur si simplu scrie "not fitted" restul se pot testa toate, am trecut prin ele numai nu le-am testat chiar pe toate, mai am timp. La programare m-am bagat numai sa vad meniul ca pentru aia mai tre sa invat dar eu zic ca acopera tot ce poate fi diagnosticat...............primul lucru va fi sa-mi aloc un EKA pe care sa-l si stiu. Salut, Mi-am luat si eu un Hawkeye si dupa ce l-am butonat vre-o ora, vad ca acum taica-meu nu l-a mai putut porni... Daca ai cumva setarile "default" pentru td5, inclusiv cele din BCU, pune-le aici ca am impresia ca am dezactivat ceva. Multumesc anticipat! Editat Octombrie 6, 2010 de Astral Land Rover Discovery td5 1999 Jaguar XJ8 2002 Ford Mustang Ecoboost 2017, Land Rover Discovery Sport (benzina) 2017 Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
sierrafery Postat Octombrie 6, 2010 Autor Partajează Postat Octombrie 6, 2010 Re: surpriza in diagnoza LR Salut, Mi-am luat si eu un Hawkeye si dupa ce l-am butonat vre-o ora, vad ca acum taica-meu nu l-a mai putut porni... Daca ai cumva setarile "default" pentru td5, inclusiv cele din BCU, pune-le aici ca am impresia ca am dezactivat ceva. Multumesc anticipat! Salut. Nu inteleg la ce setari te referi( la alea de immobiliser?), oricum eu nu am nici un fel de lista dar daca voi intelege ce doresti si se si poate, atunci ma cuplez la al meu, citesc datele pe care le vrei si ti le postez. Am patit si eu o data asa dar am dat reset cu hawkeye-ul cuplat dupa aia l-am decuplat si a luat-o. Hai noroc NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
mariusg Postat Octombrie 7, 2010 Partajează Postat Octombrie 7, 2010 Re: surpriza in diagnoza LR In orice modul exista o functie (la mine este in capitolul "other" din orice modul) de "reset adaptive value". Se foloseste pentru a reprograma calculatorul pe piesele noi ale masinii. Preia automat tot ce gaseste pe masina. Dar totusi nu cred ca puteai modifica ceva. Apropo iti da posibilitatea sa salvezi inainte de face modificari? La mine da pentru ca este pe calculator. Am istoria tuturor codurilor de eroare aparute pana acum. Land Rover Discovery 2 V8 Automatic -Thor Land Rover Discovery 2 Td5 Manual - Phoenix www.lroc.ro Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
sierrafery Postat Octombrie 7, 2010 Autor Partajează Postat Octombrie 7, 2010 Re: surpriza in diagnoza LR Hawkeye nu e asa...doar l-ai vazut...lucreaza pe direct cu datele "on screen" si nu are nici o memorie. NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
flay Postat Octombrie 7, 2010 Partajează Postat Octombrie 7, 2010 Re: surpriza in diagnoza LR Am rezolvat-o, era bateria descarcata, dar cum am umblat la programarea telecomenzilor, credeam ca am de-sincronizat ceva. Land Rover Discovery td5 1999 Jaguar XJ8 2002 Ford Mustang Ecoboost 2017, Land Rover Discovery Sport (benzina) 2017 Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
mariusg Postat Octombrie 8, 2010 Partajează Postat Octombrie 8, 2010 Re: surpriza in diagnoza LR Am inteles. Bine ca ai rezolvat. Dar totusi intrebarea mea este : aveti aceasta optiune - reset adaptive value - ? Orice schimbare de piesa care este vazuta de ecu, bcu, etc trebuie resetata ca altfel va merge pe vechile valori. Apropo Fery modulatorul merge super bine, nici o eroare decind l-am pus. Mersi inca o data. Si el a trebuit initializat cu testerul. Land Rover Discovery 2 V8 Automatic -Thor Land Rover Discovery 2 Td5 Manual - Phoenix www.lroc.ro Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
sierrafery Postat Octombrie 8, 2010 Autor Partajează Postat Octombrie 8, 2010 (editat) Re: surpriza in diagnoza LR Am inteles. Bine ca ai rezolvat. Dar totusi intrebarea mea este : aveti aceasta optiune - reset adaptive value - ? Orice schimbare de piesa care este vazuta de ecu, bcu, etc trebuie resetata ca altfel va merge pe vechile valori. Apropo Fery modulatorul merge super bine, nici o eroare decind l-am pus. Mersi inca o data. Si el a trebuit initializat cu testerul. Ma bucur sincer pt. modulator si te ajut oricand ai nevoie. La nivel de aparate, Hawkeye functioneaza altfel ca "vehicle explorer"-ul tau. Hawkeye este o varianta "handheld" a lui T4 cu optiuni putin limitate fata de T4 si nu are optiunea de care vorbesti ci un meniu de "programming" unde poti accesa toate sistemele gesionate de diversele computere. Cat despre resetarea aia de care vorbesti la orice piesa noua ....ma indoiesc. Eu pana acum mi-am schimbat sensorii ECT, MAF si TP(toti dau inputuri la ECM) si nu a trebuit sa resetez nimic......nu stiu de unde iti vine ideea asta......sau poate asa trebuie la benzinare ca la astea nu ma pricep:wink:. Modulatorul ABS nu trebuie "initializat" ci testat sa se vada daca functioneaza bine sau nu ....RAVE > ABS modulator > Refit > ...... "8. To ensure correct operation, the ABS system MUST be tested using TestBook." Hai noroc Editat Octombrie 8, 2010 de sierrafery NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
