shopy Postat Decembrie 17, 2016 Partajează Postat Decembrie 17, 2016 Am schimbat marca si am ramas cu ceva piese, unele noi, altele sh: 1. Antena electrica 150 ron 2. Caseta directie Jeep Grand Cherokee I (de pe un 4.0, posibil ok la 2.5) 100 E 3. Ceasuri bord JEEP GRAND 1993 - 1998 (Chrysler 2594AB, 56042594AB) 200 ron 4. Garnitura turbina originala Mopar 52018875 50 ron (noua) pentru: JEEP CHEROKEE 2.5L I4 Turbo Diesel, 5-Speed Manual 1995, 1996 JEEP CHEROKEE 2.5L POWER TECH I-4 Cyl., 3-SPD. AUTOMATIC,30RH SE 2-DR 2000 JEEP CHEROKEE 2.5L POWER TECH I-4 Cyl., 3-SPD. AUTOMATIC,30RH SE 4-DR 2000 JEEP CHEROKEE 2.5L Power Tech I-4 Cyl., 5-Speed Manual SE 2-DR 2000 JEEP CHEROKEE 2.5L Power Tech I-4 Cyl., 5-Speed Manual SE 4-DR 2000 JEEP CHEROKEE 4.0L POWER TECH I-6, 4SPD. AUTO,AISIN WARNER CLASSIC 4-DR 2000 JEEP CHEROKEE 4.0L POWER TECH I-6, 4SPD. AUTO,AISIN WARNER Limited 4-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 4SPD. AUTO,AISIN WARNER SE (RHD) 4-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 4SPD. AUTO,AISIN WARNER SE 2-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 4SPD. AUTO,AISIN WARNER SE 4-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 4SPD. AUTO,AISIN WARNER SPORT 2-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 4SPD. AUTO,AISIN WARNER SPORT 4-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 5-SPEED HD MANUAL Limited 4-DR 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 5-SPEED HD MANUAL SE 2-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 5-SPEED HD MANUAL SE 4-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 5-SPEED HD MANUAL SPORT 2-DR 2000, 2001 JEEP CHEROKEE 4.0L POWER TECH I-6, 5-SPEED HD MANUAL SPORT 4-DR 2000, 2001[/size][/size] 5. Kit anulare EGR 50 ron (nou) EGR Blanking Block Plate Gasket Material: stainless steel, gambit Cap diameter: 1,5 mm Error CHECK ENGINE: No JEEP CHEROKEE XJ 1997-2001 engine 2.5TD JEEP GRAND CHEROKEE ZJ/WJ/WG 1999-2001 engine 3,1TD 6. Panou sigurante 100 ron 7. Regulator tensiune Jeep (nou) 400 ron pentru Jeep dupa 1991, cu regulatorul de tensiune pentru alternator in interiorul ECU: MONTAJ si EXPLICATII: 8. Senzor Presiune ulei motor original Mopar 56026782 (nou) 150 ron pentru: Product Fitment/Applications JEEP CHEROKEE 2.1L TURBO DIESEL, 4-Spd. Automatic,47RH 1985 JEEP CHEROKEE 2.1L TURBO DIESEL, 4-SPEED AUTOMATIC 1985 JEEP CHEROKEE 2.1L TURBO DIESEL, 5-Speed Manual 1985, 1986, 1987, 1989, 1990, 1991, 1993 JEEP CHEROKEE 2.1L TURBO DIESEL, 5SPD MANUAL TRANS A881 (JA-41) 1986 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 4-Spd. Automatic,42RE 1985 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 4-Spd. Automatic,47RH 1984, 1985 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 4-SPEED AUTOMATIC 1984, 1985 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 4-Speed Manual,T3340 1985 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 4SPD MANUAL TRANS - AISIN SEIKI 1984, 1985 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 5-Speed HD Manual 1984 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 5-Speed Manual 1984, 1985 JEEP CHEROKEE 2.5L 4 Cylinder MPI, 5SPD MANUAL TRANS A881 (JA-41) 1985 JEEP CHEROKEE 2.5L 4 Cylinder MPI, A833 4 SPD MANUAL TRANS 1985 JEEP CHEROKEE 2.5L 4 Cylinder, 4-Speed Manual,T3340 1986 JEEP CHEROKEE 2.5L 4 Cylinder, 4SPD MANUAL TRANS - AISIN SEIKI 1984, 1985, 1986, 1988 JEEP CHEROKEE 2.5L 4 Cylinder, 5-Speed Manual 1984, 1985, 1986 JEEP CHEROKEE 2.5L I4 TBI GAS, 4-Spd. Automatic,42RE 1986 JEEP CHEROKEE 2.5L I4 TBI GAS, 4-SPD. AUTOMATIC,46RE 1987 JEEP CHEROKEE 2.5L I4 TBI GAS, 4-Spd. Automatic,47RH 1986 JEEP CHEROKEE 2.5L I4 TBI GAS, 4-SPEED AUTOMATIC 1986 JEEP CHEROKEE 2.5L I4 TBI GAS, 4-Speed Automatic AW4 1989, 1990 JEEP CHEROKEE 2.5L I4 TBI GAS, 4-Speed Manual,T3340 1986, 1987, 1988 JEEP CHEROKEE 2.5L I4 TBI GAS, 4SPD MANUAL TRANS - AISIN SEIKI 1986, 1987, 1988 JEEP CHEROKEE 2.5L I4 TBI GAS, 5-Speed Manual 1986, 1987, 1988, 1989, 1990 JEEP CHEROKEE 2.5L I4 TBI GAS, 5SPD AUTOMATIC 5-45RFE 1987, 1988, 1989 JEEP CHEROKEE 2.5L I4 TBI GAS, 5SPD MANUAL TRANS A881 (JA-41) 1986, 1987, 1988 JEEP CHEROKEE 2.5L I4 TBI GAS, ALL 5-SPEED AUTOMATIC 1987, 1988 JEEP CHEROKEE 2.5L I4, 5-Speed Manual 1989, 1990 JEEP CHEROKEE 2.5L Power Tech I-4 Cyl., 5-Speed Manual 1991, 1992, 1993 JEEP CHEROKEE 2.8L GM 6 CYL, 4-Spd. Automatic,42RE 1985 JEEP CHEROKEE 2.8L GM 6 CYL, 4-Spd. Automatic,47RH 1985 JEEP CHEROKEE 2.8L GM 6 CYL, 4-SPEED AUTOMATIC 1985 JEEP CHEROKEE 2.8L GM 6 CYL, 4SPD MANUAL TRANS - AISIN SEIKI 1985 JEEP CHEROKEE 2.8L GM 6 CYL, 5-Speed Manual 1985 JEEP CHEROKEE 2.8L GM 6 CYL, 5SPD MANUAL TRANS A881 (JA-41) 1985 JEEP CHEROKEE 2.8L GM 6CYL, 4-Spd. Automatic,42RE 1986 JEEP CHEROKEE 2.8L GM 6CYL, 4-Spd. Automatic,47RH 1984, 1986 JEEP CHEROKEE 2.8L GM 6CYL, 4-Spd. Automatic,MT643 1986 JEEP CHEROKEE 2.8L GM 6CYL, 4-SPEED AUTOMATIC 1984, 1986 JEEP CHEROKEE 2.8L GM 6CYL, 5-Speed HD Manual 1984 JEEP CHEROKEE 2.8L GM 6CYL, 5-Speed Manual 1984, 1986 JEEP CHEROKEE 2.8L GM 6CYL, 5SPD MANUAL TRANS A881 (JA-41) 1986 JEEP CHEROKEE 4.0L I6 MPI GAS, 4-Spd. Automatic 46RE 1989 JEEP CHEROKEE 4.0L I6 MPI GAS, 4-Spd. Automatic,44RE 1987 JEEP CHEROKEE 4.0L I6 MPI GAS, 4-SPD. AUTOMATIC,46RE 1987, 1988 JEEP CHEROKEE 4.0L I6 MPI GAS, 4-Speed Automatic AW4 1989, 1990 JEEP CHEROKEE 4.0L I6 MPI GAS, 5-Speed HD Manual 1989 JEEP CHEROKEE 4.0L I6 MPI GAS, 5-Speed Manual 1987, 1988, 1989, 1990 JEEP CHEROKEE 4.0L I6 MPI GAS, 5SPD AUTOMATIC 5-45RFE 1987, 1988, 1989 JEEP CHEROKEE 4.0L I6 MPI GAS, 5SPD MANUAL TRANS A543 1987 JEEP CHEROKEE 4.0L I6 MPI GAS, 5SPD MANUAL TRANS A881 (JA-41) 1987, 1988 JEEP CHEROKEE 4.0L I6 MPI GAS, ALL 5-SPEED AUTOMATIC 1987, 1988 JEEP CHEROKEE 4.0L I6 Power Tech, 4-Speed Automatic AW4 1991, 1992, 1993 JEEP CHEROKEE 4.0L I6 Power Tech, 5-Speed Manual 1991, 1992, 1993 JEEP CHEROKEE 4.2L I6 2BBL GAS - STD COMP, 5SPD MANUAL TRANS A543 1987, 1988 JEEP COMANCHE 2.1L TURBO DIESEL, 5-Speed Manual 1986 JEEP COMANCHE 2.1L TURBO DIESEL, 5SPD MANUAL TRANS A881 (JA-41) 1986, 1987 JEEP COMANCHE 2.5L 4 Cylinder, 4-Speed Manual,T3340 1986 JEEP COMANCHE 2.5L 4 Cylinder, 4SPD MANUAL TRANS - AISIN SEIKI 1986 JEEP COMANCHE 2.5L 4 Cylinder, 5-Speed Manual 1986 JEEP COMANCHE 2.5L 4 Cylinder, 5SPD MANUAL TRANS A881 (JA-41) 1986 JEEP COMANCHE 2.5L I4 TBI GAS, 4-Spd. Automatic,42RE 1986 JEEP COMANCHE 2.5L I4 TBI GAS, 4-Spd. Automatic,44RE 1987 9. Senzor Presiune ulei motor original Omix-Ada part 17219.08 (nou) 100 ron (1 Terminal) pentru: * Jeep Wrangler (92/95 motor 2.5,4.0), * Jeep Cherokee (XJ 92/96 motor 2.5, 4.0), * Jeep Grand Cherokee (ZG motor 4.0, 5.2 93/95) part 17219.08 10. Senzor temperatura motor original Mopar 56027012 (nou) 100 ron JEEP CHEROKEE 2.5L I4 Turbo Diesel, 5-Speed Manual 1995, 1996 JEEP CHEROKEE 2.5L Power Tech I-4 Cyl., 3-Spd. Automatic 30RH 1994, 1995, 1996 JEEP CHEROKEE 2.5L Power Tech I-4 Cyl., 5-Speed Manual 1994, 1995, 1996 JEEP CHEROKEE 4.0L I6 Power Tech, 4-Speed Automatic AW4 1994, 1995, 1996 JEEP CHEROKEE 4.0L I6 Power Tech, 5-Speed Manual 1994, 1995, 1996 JEEP GRAND CHEROKEE 4.0L I6 Power Tech, 4-Spd. Automatic 42RE 1994, 1995, 1996 JEEP GRAND CHEROKEE 4.0L I6 Power Tech, 5-Speed Manual 1994, 1995 JEEP GRAND CHEROKEE 5.2L V8 MPI, 4-Spd. Automatic 46RH 1994, 1995 JEEP GRAND CHEROKEE 5.2L V8 MPI, 4-Spd. Automatic 4RE 1996 JEEP WRANGLER 2.5L Power Tech I-4 Cyl., 3-Spd. Automatic 30RH 1994, 1995 JEEP WRANGLER 2.5L Power Tech I-4 Cyl., 5-Speed Manual 1991, 1992, 1993, 1994, 1995 JEEP WRANGLER 4.0L I6 Power Tech, 3-Spd. Automatic 32RH 1991, 1992, 1993, 1994, 1995 JEEP WRANGLER 4.0L I6 Power Tech, 5-Speed Manual 11. Senzor Volanta Mopar 56027865AB (nou) 400 ron 1997-2002 Wrangler (2.5L With MT or AT), 1997-2004 Wrangler (4.0L With MT), 1997-2000 Cherokee (2.5L) 12. Servo frana (pompa + tulumba) 100 E 13. Set bujii incandescente noi Mopar 04720600 pentru JEEP CHEROKEE XJ '95-'96 pentru: JEEP CHEROKEE XJ ZG 2.5L Turbo Diesel, 5-Speed Manual 1995 - 1996 Lungime 71 mm 14. Set difuzoare inalte (tweetere) 100 ron 15. Sigla Jeep capota 50 ron 16. Tampon arc fata original Mopar 52087636AB (nou) 100 ron JEEP GRAND CHEROKEE 1993, 1994, 1995, 1996, 1997, 1998, 2001, 2009 JEEP LIBERTY 2007 JEEP WRANGLER 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2013 Pentru detalii PM sau 0722497066 E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Ianuarie 14, 2017 Autor Partajează Postat Ianuarie 14, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) Valabil! E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Februarie 26, 2017 Autor Partajează Postat Februarie 26, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) De actualitate, mai putin punctul 8. E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Martie 18, 2017 Autor Partajează Postat Martie 18, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) Valabil, fara caseta directie . E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Aprilie 2, 2017 Autor Partajează Postat Aprilie 2, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) Valabil! E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Mai 28, 2017 Autor Partajează Postat Mai 28, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) Hai mai sus ca se poate! :old E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Iunie 25, 2017 Autor Partajează Postat Iunie 25, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) Valabil! E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Iulie 16, 2017 Autor Partajează Postat Iulie 16, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) De actualitate: 1. Antena electrica 150 ron 3. Ceasuri bord JEEP GRAND 1993 - 1998 (Chrysler 2594AB, 56042594AB) 200 ron 4. Garnitura turbina originala Mopar 52018875 50 ron (noua) 5. Kit anulare EGR 50 ron (nou) 6. Panou sigurante 100 ron 7. Regulator tensiune Jeep (nou) 400 ron pentru Jeep dupa 1991, cu regulatorul de tensiune pentru alternator in interiorul ECU: MONTAJ si EXPLICATII: https://www.youtube.com/watch?v=utXj...PMvgRumlPpt4vA 8. Senzor Presiune ulei motor original Mopar 56026782 (nou) 150 ron 9. Senzor Presiune ulei motor original Omix-Ada part 17219.08 (nou) 100 ron 10. Senzor temperatura motor original Mopar 56027012 (nou) 100 ron 11. Senzor Volanta Mopar 56027865AB (nou) 400 ron 12. Servo frana (pompa + tulumba) 100 E 13. Set bujii incandescente noi Mopar 04720600 14. Set difuzoare inalte (tweetere) 100 ron 15. Sigla Jeep capota 50 ron 16. Tampon arc fata original Mopar 52087636AB (nou) 100 ron Contact PM sau 0722497066 E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Septembrie 14, 2017 Autor Partajează Postat Septembrie 14, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) De actualitate. E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Octombrie 23, 2017 Autor Partajează Postat Octombrie 23, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) De actualitate. E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
shopy Postat Noiembrie 19, 2017 Autor Partajează Postat Noiembrie 19, 2017 Re: Vand cateva piese Jeep (antena el., caseta dir., ceasuri, regulator tensiune, bujii, cativa senzori etc) Valabil! E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard) Link spre comentariu Distribuie pe alte site-uri Alte opțiuni partajare...
