Victory Posted March 14, 2021 Author Share Posted March 14, 2021 E posibil....Nu stiu cum e posibil, dar atunci cand am desfacut aerisitorul, fara sa apese cineva pedala, a țasnit lichid dupa care s a deblocat etrierul. Land Rover Discovery 2 Td5 2001 Link to comment Share on other sites More sharing options...
sierrafery Posted March 14, 2021 Share Posted March 14, 2021 Schimba pompa hidraulica 1 NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Victory Posted March 17, 2021 Author Share Posted March 17, 2021 Am schimbat o. Aceiasi problema. :( Land Rover Discovery 2 Td5 2001 Link to comment Share on other sites More sharing options...
sierrafery Posted March 18, 2021 Share Posted March 18, 2021 Si cu mufa scoasa de la modulator ? ai vacuum la servo ? Mai explica o data exact ce se intampla. NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Victory Posted March 20, 2021 Author Share Posted March 20, 2021 Cu mufa scoasa. Pur si simplu se blocheaza rotile dreapta fata si stanga spate. Pedala se intareste. Desfac aerisitorul si sare lichid fara ca cineva sa sa actioneze frana. Apoi merge cativa km dupa care din nou aceiasi problema. Am schimbat pompa de la pedala, am inlocuit tot lichidul. Placute noi, culisantele merg, etrieri ok. Mai ramane modulul de abs. Land Rover Discovery 2 Td5 2001 Link to comment Share on other sites More sharing options...
sierrafery Posted March 20, 2021 Share Posted March 20, 2021 Si cu modulatorul reconectat nu mai face asta ci doar intra TC in actiune ? iar cand intra TC ti se aprinde si martorul ? NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Victory Posted March 20, 2021 Author Share Posted March 20, 2021 Cu modulstorul nu am mi am putut da seama deoarece nu pot sa merg pe distanta mai mare ca franeaza mereu. Da, se aprinde TC ul Land Rover Discovery 2 Td5 2001 Link to comment Share on other sites More sharing options...
sierrafery Posted March 20, 2021 Share Posted March 20, 2021 Dar cu modulatorul reconectat si cu releul pompei(R19) scos ? NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Victory Posted March 20, 2021 Author Share Posted March 20, 2021 Cu releul abs scos mi a facut. Cu siguranta Abs, nu s au blocat. Land Rover Discovery 2 Td5 2001 Link to comment Share on other sites More sharing options...
sierrafery Posted March 20, 2021 Share Posted March 20, 2021 Trebuie incercat cu testerul pe ''outputs'' fiecare valva NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Victory Posted March 20, 2021 Author Share Posted March 20, 2021 Ok. Verific maine. Cu motorul pornit sau oprit? Cum verific valvele, rebuie sa se auda un sunet aume? Stiu ca la o anumita comanda porneste abs ul. Land Rover Discovery 2 Td5 2001 Link to comment Share on other sites More sharing options...
sierrafery Posted March 20, 2021 Share Posted March 20, 2021 Doar cu contactul pus si trebuie toate sa clicaie la fel pe test 1 NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Victory Posted March 22, 2021 Author Share Posted March 22, 2021 Functioneaza toate 8 valve. Cum as putea verifica daca vacuum? Am miscat mufa care intra in tulumba si s a auzit un fasâit La fel si cand am schimbat si pompa de la pedal s a auzit... Land Rover Discovery 2 Td5 2001 Link to comment Share on other sites More sharing options...
sierrafery Posted March 22, 2021 Share Posted March 22, 2021 Nu stiu cum sa verifici vacuumul, daca simti absorbtie pe teava ar trebui sa fie ok, totusi si daca este vacuum poate fi problema la servo sau infundat circuitul ala, aici ti-ar trebui un mecanic dibaci care intelege cum functioneaza sistemele wabco, deja ma depaseste dar nu am mai vazut defectiune de modulator sa dea simptome asemanatoare.Bafta si revino cu ce a fost dupa ce se rapara ca sa stim si noi. 1 NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
