Problema kawasaki brute force
ursu
Va salut am o problema cu un atv kawasaki brute force 750 s-a aprins martorul pentru cureaua de transmisie la bord si motorul a intrat in avarii am inlocuit cureaua dar nu stiu cum se reseteaza senzorul respectiv de la curea deoarece martorul a ramas aprins si motorul in avarii.Daca are cineva solutia va rog sa ma ajutati, multumesc anticipat:hl
Re: Problema kawasaki brute force
Nu ar trebui sa intre in nicio stare de avarie.
Uite, procedura de resetare, o traduci tu din engleza:
1) remove seat, unplug black and grey 4-pin connectors
2) swap plugs, grey to black and black to grey
3) turn on ignition switch, belt light should be flashing quickly
4) disconnect 2-pin belt switch above torque converter cover, belt light should be flashing slowly
5) let flash for at least 5 seconds
6) turn off ignition switch
7) reconnect 4-pin connectors black to black and grey to grey, reconnect 2-pin belt switch
http://illiweb.com/fa/i/smiles/icon_cool.gif turn on ignition switch to confirm belt light is out
