Land Rover TD4 Posted August 28, 2019 Author Share Posted August 28, 2019 revin dupa o absenta consistenta, azi am comandat faruri europa sh,rugamintea mea este pentru cunoscatori,sa ma indrumati ce trebuie sa verific la primirea lor,am verificare colet,sa fie de Europa,multumesc anticipat. Link to comment Share on other sites More sharing options...
lu Posted August 29, 2019 Share Posted August 29, 2019 Te uiti la striatiile oglinzii ce pleaca de la becul de faza scurta in stanga si in dreapta becului, sunt inclinate invers fata de cele de UK. Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted August 29, 2019 Author Share Posted August 29, 2019 Am rezolvat,in partea de jos a farului este diferenta dintre LHD si RHD cel LHD are 2 sageti indreptate catre exterior, si RHD are 2 sageti indreptate catre exterior si una catre interior,in plus de asta pe ale mele era stantat LHD pe ambele. Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted August 31, 2019 Author Share Posted August 31, 2019 ieri am cumparat ceasuri de bord Europa, ptr Freelander FL ,se schimba usor? multumesc Link to comment Share on other sites More sharing options...
lu Posted September 2, 2019 Share Posted September 2, 2019 In 15 minute termini. Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted October 16, 2019 Author Share Posted October 16, 2019 chiar atata a durat,misiune indeplinita Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted October 16, 2019 Author Share Posted October 16, 2019 Next step: am cumparat faruri de Europa, au fost polishate iar ieri le-am aplicat folie protectoare ,astazi incep operatiunea de schimbare a lor, ma intereseaza ceva sfatuti cu privire la demontarea barii,succesiunea operatiilor,multumesc Link to comment Share on other sites More sharing options...
lu Posted October 16, 2019 Share Posted October 16, 2019 https://workshop-manuals.com/landrover/freelander-b/exterior_fittings/repairs/bumper_assembly_front_from_04my/ Scrie exact cum se demonteaza. Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted October 16, 2019 Author Share Posted October 16, 2019 Cu putin efort,niste suruburi s-au opus, am reusit sa demontez bara ,sa scot farurile, am curatat si gresat toate imbinarile filetate,am inlocuit unele clipsuri ruginite,am pus farurile europene,si am remontat ,toata tevatura a durat cca 4 ore ! Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted October 16, 2019 Author Share Posted October 16, 2019 mai am o rugaminte la cei cunoscatori: as vrea sa fac o proba la webasto,in vederea pregatirii ptr sezonul rece, cum pot face asta acum dat fiind faptul ca nu este o temperatura ca sa pornesca singur. Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted October 17, 2019 Author Share Posted October 17, 2019 rezolvat, am facut strap la mufa de la senzor si a pornit insa mi sa adeverit banuiala ca nu se alimenteaza cu motorina, mergem inainte sa desfundam alimentarea! Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted December 7, 2019 Author Share Posted December 7, 2019 (edited) Help,help,rugaminte mare de tot, imi trebuie o recomandare de termostat eventual cod,ptr Td4 82kw,multumesc mult de tot,si inca o intrebare: cum se poate verifica un termostat daca deschide la temperatura optima(inainte de montare pe masina) Edit :Am gasit cod de piesa,insa nu stiu ce sa aleg ?vreo parere avizata gasesc?multumesc Edited December 7, 2019 by Land Rover TD4 Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted September 23, 2020 Author Share Posted September 23, 2020 (edited) salutam cu respect ,daca nu deranjez ajutati-ma si pe mine cu un cod ptr rulmenti cardan Bearmach,multumesc Am gasit codul insa nu-i gasesc la nici un magazin, daca cineva ma poate indruma unde sa-i comand multumesc anticipat Edited September 23, 2020 by Land Rover TD4 Link to comment Share on other sites More sharing options...
sierrafery Posted September 23, 2020 Share Posted September 23, 2020 Da codul TOQ000040 pe google si apar magazinele online ... apare la unul din ele pe stoc aici in Romania NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted September 23, 2020 Author Share Posted September 23, 2020 (edited) Eu am gasit Bearmach cu codul TOQ00004 -dar nu-l gasesc deloc disponibil-ce ai pus tu mai sus este PIESA DE ORIGINE OE LANDROVER TOQ000040- si pe mine ma interesa Bearmach Edited September 23, 2020 by Land Rover TD4 Link to comment Share on other sites More sharing options...
sierrafery Posted September 23, 2020 Share Posted September 23, 2020 Bearmach exista sansa sa fie chinezism NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
teddybear Posted September 24, 2020 Share Posted September 24, 2020 Eu am gasit Bearmach cu codul TOQ00004 -dar nu-l gasesc deloc disponibil-ce ai pus tu mai sus este PIESA DE ORIGINE OE LANDROVER TOQ000040- si pe mine ma interesa Bearmach Cauta piesa compatibila de la GKN, nu-ti va parea rau! Eu merg cu ei de circa 3 ani... aproape 60.000km! It's not a "Jeep thing" it's the real thing ....LAND ROVER ! Land Rover Owners Club Romania Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted January 30, 2025 Author Share Posted January 30, 2025 Vin cu o problema, imi trebuie sa inlocuiesc pragurile de pe masina intrucat datorita varstei sau cam cariat, se gasesc praguri noi ptr aceasta sau trebuiesc facute manual ? multumesc Link to comment Share on other sites More sharing options...
sierrafery Posted January 30, 2025 Share Posted January 30, 2025 Salut, deschizi sectiunea de carserie(Body & chassis) si acolo vezi exact toate codurile pieselor existente candva pe piata, dai codul pe google si vezi daca se mai gasesc noi sau nu sau poate sunt noi dar foarte scumpe apoi poti sa decizi UItasem linkul CODURI PIESE NU RASPUND USERILOR CU PROFIL INCOMPLET LA MASINA(model, an, motor, transmisie), NU RASPUND PE PM LA PROBLEME TEHNICE SAU DE INTERES GENERAL Discovery Td5 ES , "00. manual, ECU tunat, intercooler marit...merge de rupe Link to comment Share on other sites More sharing options...
Land Rover TD4 Posted April 3, 2025 Author Share Posted April 3, 2025 Va salut , vin cu o problema la care caut lamurire: este vorba de Rulmentul de sarcina ,acei ,,Palieri'' ,as vrea sa-i schimb,i-am gasit dar sunt cam scumpicei, totodata am gasit un Set reparatie rulment sarcina amortizor LAND ROVER FREELANDER I (L314) 2.0 Td4 4x4 diesel 112 cai MAXGEAR 72-4551si m-ar interesa daca cineva a folosit acest set de reparatie si daca se inlocuieste usor ,multumesc Link to comment Share on other sites More sharing options...
