Drujba cu acumulator 56V EGO CS1400E la cutie, folosita de 2-3 ori!
shopy
Am cumparat-o in urma cu doi ani in ideea de a-mi procura lemne de foc la pescuit. Deoarece partidele mele la Dunare se intind pe 5-7 zile si masina era mereu plina, am luat-o cu mine doar de 2-3 ori... Practic e noua! Pentru cine crede ca e 'jucarie', aveti multe clipuri pe youtube sa va lamuriti.
PRET FIX 1000 lei, nu negociez (nu tin neaparat s-o dau)!
Prefer RIDICARE PERSONALA cu proba (Bucuresti - Titan), sau trimit in tara dar userilor noi NUMAI cu plata transportului in avans!
telefon 0722497066 (sau PM)
EGO CS1400E
High-Efficiency Brushless Motor - Delivers longer run time, low vibrations & an extended motor life
35cm Bar & Chain - Provides effortlessly smooth cuts & a low-kickback design for safety
6800 RPM - Delivers the power to cut through hardwood, softwood, branches, & more
Weather Resistant - Rugged construction keeps your tool safe under more conditions
Revolutionary battery technology for premium battery performance.
WEATHER RESISTANT CONSTRUCTION
Rugged construction keeps your tool safe under more conditions.
Voltage 56 Volt
Guide Bar Length 350 mm
Maximum Cut Diameter 350mm
No Load Speed 6800 RPM
Chain Pitch 9.5mm
Chain Gauge 1.1mm
Saw Chain Type 1.1mm Gauge Chain with 9.5mm Low Pro Pitch
Reversible Bar Yes
Chain Kickback Brake Yes
Guide Bar Type 144MLEA041
Chain Oil Tank Capacity 150 ml
Guaranteed sound power lever 75 dB(A)
Weight (without battery pack, chain sheath) 3.81kg
Editat de shopy
E loc sub soare pentru toata lumea. Mai ales ca toata lumea vrea sa stea la umbra. (Jules Renard)
